Hi. Using the 4-Way Optimization/dual intelligent processors app, under TPU, it won't save my settings. I need "OC Voltage" to be set to 1.3 always, whereas it defaults to 1.275, and If I forget to change it on startup, my computer crashes after a while. I've no idea where to find this setting in Bios. And why doesn't this program save your changes? the autosettings created by the 4wayOptimization button thing always BSOD's my pc, and I have to push the voltage up just a little which seems to solve the issue, but every time i start my computer.
Please help.
(Running at 4.5ghz btw - doesn't go over 75 degrees in prime95 which is good).
See attachement
