Haha, well that all kicked off. I think it's been cleared up.. but I certainly haven't tried to power my PWM DDC pump using a fan header.. I'm no fool. the fan header simply provides the RPM control via the PWM function. My pump is indeed connected correctly via molex. My point stands.. 4-PIN hears are PWM headers as non PWM 4-pin should simply be 3-pin headers.. and so it should be clearly documented. But nevermind, the DDC pump isnt loud at 4000rpm so I'm over it.
J.
