02-03-2015 02:03 AM - last edited on 03-06-2024 02:28 AM by ROGBot
02-03-2015 04:37 AM
02-04-2015 01:00 PM
Fist3365 wrote:
I actually have a very similar setup. I have the same MOBO and I have the Sapphire R9 295x2. It has been running without any problems since I installed it. When I received my GPU from newegg, I first re-installed my windows 7 so I can start with a clean slate. Then I went through installing all the other programs as well. Since mine works, it shouldn't be any compatibility issue. I will try and answer any other questions you may have, but their are other people on this forum who have way more technical knowledge than I do.
02-05-2015 07:19 PM
02-03-2015 05:02 AM
02-03-2015 07:06 PM
hax0rmort wrote:
Are you changing the secure boot or CSM by chance? I know you said that you don't have to make any changes to start this cycle of no output, but very curious for your response. I have 2 290x, which is what you have essentially, and if I start with a clean BIOS and change the CSM to Disabled, I can no longer boot into BIOS and just get a black screen from that point on. I have to clear to get back in BIOS or to POST. Let me know.
02-12-2015 08:51 PM
05-06-2015 03:25 PM
07-23-2015 02:57 PM
05-08-2015 05:31 PM
