2-way SLI on Maximus V Extreme - best slots 8x/8x or 8x/16x?
feniks
Level 11
I am looking at ASUS MVE manual and it seems that for 2-way SLI ASUS proposes using Intel CPU native bandwidth for both cards (8x/8x natively) using slots PCIe3.0_1 (top first) and PCIe3.0_2B (third from top). I know that switches/bridges may cause some lag, so it makes sense *IF* each of cards doesn't exceed the PCIe3.0 8x bandwidth (I think 670 2GB cards don't but I am unsure of it).
Also this configuration allows for better air flow between cards which probably matters if one relies on air cooling ... I don't, both cards are water cooled.
however I see there is also another config possible which is based on 3-SLI configuration and for 2-SLI it would suggest using both top first and second slots, PCIe3.0_1 & PCIe3.0_2A respectively for x8/16x.
tomorrow I will be installing my second 670 2GB for 8x/8x config for now and I hope it works fine (no lag related to PLX chip switching).
does anybody have some benchmarks comparing same cards and CPU clock (and memory) running 2 cards in each of mentioned configurations?
Thanks!
.: R3C0NF1GUR3D :.
ASUS MVE :: 3770K bench @ 5.2GHz (delidded) :: 2x4GB Mushkin 996990 @ 2400MHz CL10 @ 1.7V :: evga 670 2GB SLI @ 1280/7108 :: Mushkin Chronos 240GB SSD RAID0 (OS) :: WD RE4 2TB (storage) 2TB :: Hitachi Deskstar 5K300 2TB (backup USB3.0) :: ASUS VG248QE 24'' 144Hz monitor
My rig with pictures
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
52 REPLIES 52
stackoverflow13
If you notice all that evga have done is double the clock value figure of asus because the 690 is 2 cards ie 2x 3004mhz. This is band marketing & wrong. all gtx 690's are the same. all have a memory clock of 3004MHz.
Asus Maximus XI Formula: i9 9900k @ 5.2 GHz: 2x8GB team group Xtreem Edition @4000Mhz: 2xRTX 2080TI: 1xSamsung 970 Pro, 3xSamsung 860 pro 2TB ssd: Creative Zxr: Custom water cooled loop: 2xAsus PG27UQ 4k @144Hz Gsync.
you mean there are no different between asus and evga card? if its so ill go with asus. thankx mate.
It ain't over till the fat lady sings :cool:...
feniks
Level 11
actually the effective memory clock on 600 series is like that, around 6GHz while most software apps reports it halved (3GHz), it's normal. both specs (EVGA & ASUS) are correct though, just using different methodology 😉
for instance my 670 memory runs at 3506MHz as reported in GPU-Z or Precision X, but in fact that is effective 7012MHz. GDDR memory... effective double data rates, just like with DDR3 RAM, CPU-Z will report 1200MHz while one is running 2400Mhz.
.: R3C0NF1GUR3D :.
