2-way SLI on Maximus V Extreme - best slots 8x/8x or 8x/16x?
feniks
Level 11
I am looking at ASUS MVE manual and it seems that for 2-way SLI ASUS proposes using Intel CPU native bandwidth for both cards (8x/8x natively) using slots PCIe3.0_1 (top first) and PCIe3.0_2B (third from top). I know that switches/bridges may cause some lag, so it makes sense *IF* each of cards doesn't exceed the PCIe3.0 8x bandwidth (I think 670 2GB cards don't but I am unsure of it).
Also this configuration allows for better air flow between cards which probably matters if one relies on air cooling ... I don't, both cards are water cooled.
however I see there is also another config possible which is based on 3-SLI configuration and for 2-SLI it would suggest using both top first and second slots, PCIe3.0_1 & PCIe3.0_2A respectively for x8/16x.
tomorrow I will be installing my second 670 2GB for 8x/8x config for now and I hope it works fine (no lag related to PLX chip switching).
does anybody have some benchmarks comparing same cards and CPU clock (and memory) running 2 cards in each of mentioned configurations?
Thanks!
.: R3C0NF1GUR3D :.
ASUS MVE :: 3770K bench @ 5.2GHz (delidded) :: 2x4GB Mushkin 996990 @ 2400MHz CL10 @ 1.7V :: evga 670 2GB SLI @ 1280/7108 :: Mushkin Chronos 240GB SSD RAID0 (OS) :: WD RE4 2TB (storage) 2TB :: Hitachi Deskstar 5K300 2TB (backup USB3.0) :: ASUS VG248QE 24'' 144Hz monitor
My rig with pictures
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
52 REPLIES 52
for my sadness i've tried to put the videocards in the right slots (1 & 2b) and install game on asecondary hdd and the result is the same.
ASUS MAXIMUS V EXTREME - I7-3770K @ 4.6 GHZ - 8GB G.SKILL TRIDENT X @2666MHZ - NOCTUA DH-14 -2-WAY SLI ASUS GTX 680 DC2T - PSU SEASONIC 1000W - MONITOR ASUS PB278Q 2560X1440 - 60 GB SSD OCZ AGILITY 3 + 1 TB SEAGATE BARRACUDA 7200.14 (INTEL SMART RESPONSE) - CASE CM STORM
stackoverflow13
Then there's definatly something else wrong. Ithought U said you had triple card did it fit in 1 + 2b? Anyways, I've seen this kinda thing a few times, with my own sys, the only way round it was to to do a clean install. (are you using win 8 or 7 x64?
Sorry I couldn't be more help
Asus Maximus XI Formula: i9 9900k @ 5.2 GHz: 2x8GB team group Xtreem Edition @4000Mhz: 2xRTX 2080TI: 1xSamsung 970 Pro, 3xSamsung 860 pro 2TB ssd: Creative Zxr: Custom water cooled loop: 2xAsus PG27UQ 4k @144Hz Gsync.
yes i have 2 3-slot cards and placed in 1 and 2b leaves about 5 millimeters between them this is why i placed them in 1 and 3 slot. i have windows7. do you think that with windows 8 i could solve the problem?? it is such a pain in the *** to do a fresh install 🙂
feniks
Level 11
are those cards 600 series or 500?
if they are 600 then you need to turn off the in-game VSYNC, this is what is cutting your FPS into half whenever the physical FPS drops below 60, that's how it works.
instead, enable the Adaptive VSYNC in NV Control panel 3D settings, it will cap FPS at 60 (or whatever native for your screen) and automatically disable it when you actual FPS drops below (so it doesn't get halved).
if cards are 500, then you can disable vsync, but most likely you will see sceen tearing whenever FPS spikes above 60 or whatever your screen's native refresh rate is.
.: R3C0NF1GUR3D :.
with regards win 8 I noticed that with the latest drivers I get 10 to 15 fps more on win8 than win 7 (dual boot setup) It's probably something else but there you are.
@Feniks With the new driver crysis 3 already has a custom profile, so that should be ok. Mines set to use the 3d application setting
stackoverflow13
Good point my old mate forgot that little nugget of info
when i deactivate vsync in game nothing changed.ivetried to activate adaptive in nvidia panel but i got worse fps. nowwith all set to very high with AA in fxaa at 1440 p i got between 47 and 60 fps.if i put msaa 2xi got steady 37fps, the same with txaa high. if i go to 1080p so i stay on average 55 fps with txaa high
rog-classified
Hey guys little help please. I manege to sell my asus gtx 680 d2t card. lost 100usd but no choice i have to sell that because 3 slot card make me mad. im plaining to buy gtx 690. is it any different evga and asus card, with one i should buy?
It ain't over till the fat lady sings :cool:...
stackoverflow13
No all 690's are built against reference. Might I suggest 2 680's would be a better choice, there are quite a few 2 slots designs no available + 2 of those are better than a 690
rog-classified
can you please explain this. asus and evga 690 is almost same. only one different. asus Effective Memory Clock is 3004MHz and evga Effective Memory Clock 6008MHz. what this meen. this is the only different i can see on specs. what is this and is this is going to do some performance issue? please explain to me. ill add a photo of that, thanks.
17892
