12-22-2024 05:02 PM
I've noticed that the XG Mobile revs up (for no reason) in constant increments.
I've observed this on Silent and Performance mode (Turbo is obviously just constantly loud)
Every few minutes it just gets extremely loud at a slow constant rate, even when I have nothing open, as few background tasks running as possible. Then after it cools off it gets silent again.
You can see the GPU frequency vs Temperature here, and the temperature matches when it gets loud
The XG Mobile on silent mode, seems to sit at 1110MHz, and goes from 48 degrees up to about 58 degrees then back down. On a sine curve like the above graph. Its usage is 0-3%.
Its very annoying and I don't know what to do about it - has anyone had this issue / solved it - or have any suggestions?
Notes:
I have the Asus Rog Ally Extreme CPU with 3080 150W XG Mobile.
I have dusted the crap out of it, so its not choked (at least in any way that compressed air can help).
Restarting, disconnecting and reconnecting, and all that doesn't seem to change any variables.
01-06-2025 04:55 PM
mine is the same. already repaste it but will do it again lol
