Strix GeForce® GTX 1070 OC edition 8GB led problem
Trexmark
My GPU card had nice AURA colours when I switched off the PC, together with the ASUS Maximus IX Formula motherboard. However now it stopped having those lights, while the Mobo still have the lights on if switched off. The Leds are functioning well when the PC is on, but I would like to have the lights on always, as it was before. Any idea what has switched off the GPU Leds and how can I put them on again? Thanks
Nate152
Hi Trexmark
You may be able to keep the lights on, in the bios - Advanced tab - RGB Effects.
Thank you Nate, I haven't mentioned that the RGB effects are ON in the BIOS. (this is why the lights on the MOB are on even when the PC is off.
I attach picture about BIOS setting and the switched off lights. (Mob lights are on, GPU is only the white tiny LED, instead of the LOGO and other RGB Leds.) Any other idea? Thanks
Can anybody confirm, that he has the GPU Aura LEDs on (together with the motherboard Leds) when the PC is off or in sleep mode? Thanks
