12-02-2025 03:20 PM
Hello,
i bought a use rtx3080 tuf gaming oc from 2020. This one has the first Bios version installed. So the fan stop is not working properly.
I wanted to update the VBIOS and for this i downloaded the BIOS update tool V2 from 2020/12/14 directly from Asus.
I unpacked these and started the exe.
But i get the error:
"A driver cannot be loaded on this device.
Driver: IOMap64.sys
A security setting has identified this as a vulnerable driver and is preventing it from loading."
I dont know for what i should search to get it running.
Iam using Windows 11 if this a nessecary information.
12-02-2025 03:47 PM - edited 12-02-2025 03:49 PM
Hello Cronyx1
This could be due to the Windows Memory integrity setting.
Try turning this OFF:
1) In the taskbar Search bar, type in Core isolation and click it.
2) Turn OFF Memory integrity.
3) Restart your pc.
4) Try the Vbios update.
12-03-2025 02:30 AM
Hello,
memory integration was off all the time.
