RTX 5090 12V-2x6 power connector is still a concern for users?
kolelvo2
Do you think this is still a common operational issue and we need to stat worry?!!
Many recommendations been suggested for safer use so far. The solution provided by Astral RTX 5090 was great through GPU Tweak III software that gives color coding for the safety of 12V-2x6 connector.
Besides Astral solution, I am working at the moment to have solution for another preventive and simple “very simple” action that should work nicely together which might enable very long gaming session with stressed and loaded RTX 5090 . Will update soon after testing the idea.
0 REPLIES 0
