RTX 2080 TI - GPU Fan Speed Bug
StealthRain
Hello guys,
I have a problem with the fan curve on my ROG-STRIX-RTX2080TI-O11G-GAMING. By now I have tried everything I could think of, but I found no
solution. In short, I cant control my GPU Fan Curve. Everytime my GPU hits 75c the fans (on the gpu) ramp up to 100% even if the fan curve and GPU Tweak II tell something different (see screenshots).
In the "Settings" screenshot you can see my active fan curve and as you can see, the only time the fans should go 100% is when the GPU hits 85c. Now comes the strange part. Eventhough the software tells me fans run at 82% in reality they run at 100% (you can tell when comparing the RPM from the "Max" screenshot with the second screenshot).
Question: Has anyone experienced the same problem and do you guys have any advice on how to fix this?
And yes I have tried MSI Afterburner Beta 11, same problem with the fan curve.
Best regards
UPDATE: RMAed the card
0 REPLIES 0
