05-14-2018
11:48 PM
- last edited on
03-06-2024
08:48 PM
by
ROGBot
05-15-2018 01:29 AM
05-15-2018 03:48 AM
Silent Scone wrote:
Hi Matty, I believe this is due to slight min RPM tolerance between the fans. As long as the card is being kept cool I wouldn't concern yourself with it.
05-15-2018 08:58 AM
05-15-2018 10:33 AM
xeromist wrote:
If the noise is a concern you may need to use your GPU overclocking tool of choice to play with the fan curve. Or just overclock it. If the card is hotter the fans will keep spinning. 😄
