10-03-2015 09:24 PM
10-04-2015 01:43 AM
10-04-2015 03:09 AM
Arne Saknussemm wrote:
Download DDU ...that will run in safe mode and uninstall all Nvidia stuff.
Then reinstall latest GPU driver.
If that doesn't work maybe clean OS install if things are really badly scrambled.
10-04-2015 04:02 AM
10-04-2015 04:22 AM
Sorry, by clean install I mean re-install Windows....if things have become so scrambled...
You have uninstalled all Intel drivers as well....
BIOS should automatically select discrete GPU if installed and leave iGPU alone...if that is not the case make sure there are no power problems with GPU
Though the pics above show the game running on GTX 960 not intel
10-04-2015 04:26 AM
10-04-2015 04:51 AM
Have you tried using restore point to return system to before you did the DX9 install from the game?
10-04-2015 05:11 AM
