Asus Strix 980 Ti - small rattle noise when fans are spinning.
sde444
Hello. Its my next topic here, but i am left only with one problem .My card is Asus Strix 980 Ti.When i am launch a game, and when fans ramps up, i can hear small rattle noise. Then after 5 second noise is gone. Is this normal or i must rma card?
Should i be worried about this?
No there is not any cables interfering. I checked it. So live with this or rma card?Its only small rattles for few seconds when fans are spinning , then noise is gone.
9 REPLIES 9
Nate152
Hello sde444
That's something to take up with tech support, they will advise you if you should rma your strix 980ti or not.
sde444
Here is the noise what i am talking about:
I have the same rattle noise when fans coming to spin up. Afer a while noise is gone. So iguess its not normal?
Nate152
I don't hear anything in the video, am I going deaf? 😄
If yours is making the same noise I can't hear I wouldn't worry about it.
Nate152
No the noise is not normal, get a hold of tech support and explain the problem to them.
There's not much we can do for you here.
The noise is only when fans are starting ( accelerating ). Then after a moment on higher rpm noise is gone and its ok. What do you think about it?
Nate152
It's a tough call, as long as it doesn't get any worse I might not worry about it, but if it does get worse then it's a problem. if it gets worse after the warranty period it's even a bigger problem.
sde444
It gradually disappear. And its sound like this:
https://www.youtube.com/watch?v=4ceIxnzd97M
Now that you mention it ... my 980ti strix also rattles. It's the first fan and if I slightly push up the coolers housing it disappears.
Seems like a grinding/rattling noise.
I am sending mine back.
I also did a quick sound record before returning the card so I have some evidence.
https://www.youtube.com/watch?v=jDjZ0FgIIfU
