Asus RTX 2080 super, i press button on card to turn led lights off, but on reboot....
Daytrader
Asus rtx 2080 super, i press button on card to turn led lights off, but on reboot there back on, then i have to take case cover off again to press the button that turns them off again, is this normal ? i do not have the Aura Sync software installed, is the only way to turn them off permanently by having Aura Sync installed, was hoping just the button would turn them off for good.
Alicatt
I go into the Aura program and turn it off from there
0 Brightness
0 Saturation
and then sync on shutdown
Apply
then click Off on the radio button and then close the program
99.9% off the time it is off on reboot... except when the darn cat jumps on the power switch on the case that some how resets back to the LEDs being on 😞
Daytrader
Yeh, thx for reply, yes i have since done that, was just hoping to be able to do it without installing the extra software, but all good now, thx
