02-28-2015 02:18 PM - last edited on 03-06-2024 03:14 AM by ROGBot
04-08-2015 06:24 PM
04-09-2015 08:05 AM
04-09-2015 08:40 AM
04-09-2015 11:48 PM
Tristanian wrote:
The problem is that when the card overheats, it downclocks the GPU, and performance becomes really crappy. I'd suggest you try to manage the cables in your case and try to put more fans in it to make sure it is properly ventilated. This is what I will try to do... The problem is that I have some watercooling equipment that I need to manage too (and some cables too). Let's hope this will fix the problem.
04-10-2015 07:13 PM
04-14-2015 01:08 AM
Tristanian wrote:
wow bro; you did a very good job concerning cable management and ventilation ... Nothing to say there!!! I was going to ask you to test the card without that lever, but you already mentioned that you did that.
I'm saying this because yesterday, I decided to remove my watercooling pump from the case and put it outside because the card was partially touching it. I left the pump outside and the case open just to test if anything changes. I was extremely surprised when I noticed that my temps became normal .... the GPU never reaches that scary 92° under load in Furmark (it was 68 max) . For some reason, GPU won't boost on default values, so I need to tweak it a little bit to reach 1250 or 1300 MHZ.
Now, I think you should forget (at least momentarily) about the noises and coiling ... Try to remove that lever and see if your GPU temperature drops ... I believe that the top of the card (the part with the fans) can move easily with the slightest pressure, which causes the GPU not to contact the part that cools it down; I suggest you leave the card hanging there and check the temps again. if you fix the temps problem (which is the worst in my opinion), then you can focus on the other (relatively minor) problems. Also, using the middle PCI express port will ensure that the card is positioned directly in front of one of the fans that blow air into the case, and closer to the one blowing hot air out of it (which can only be a good thing). I'm not an expert or anything, but this is what I got so far; I need to share it with you, maybe it will help solve your problem.
Just one final (rather stupid) question: How do you measure your VRM temps??? (I read somewhere that it can reach 120 °, and that it's only in danger if it exceeds it ... again, I'm not sure).
Good luck mate.
