Asus GeForce RTX 5090 Astral Power Detect+ 12VHPWR warning after loading into Tarkov Raid
Stoick1337
Hello everyone,
After loading into the raid the power detect warning went off and when I looked in gpu tweak 3 the pin 4 was reading a little over 10A and after a bit it went down. After watching for a while longer I noticed pins 4, 5, and 6 all had higher readings than the other pins. I was wondering if this is a known issue and if there is a way to fix it or avoid it any insight or answers are appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Silent_Scone
Super Moderator
Hi @Stoick1337
This is a power imbalance that Power Detector + is designed to notify you of. The warning will trigger if one or more pins exceed 9.2A. Check that all power connectors are fully seated for the GPU, and if so, consider replacing the cable.
Silent_Scone
Super Moderator
Hi @Stoick1337
Stoick1337
Thank you for the response I will double check to make sure the cable is seated properly. I don't think the cable would be the problem as it is the cable that came with the ROG Thor 1200 platinum II.
