Hello,
My second topic and unfortunately also with a problem(first one was buzzing under load which I learn to tolerate). So I decided to check out how loud fans are at higher speeds and I found something pretty bad, some kind of vibration when fans are spinning, its present even on lowest speeds but rest of pc fans are kind of hiding it but from around 40% of fans speed it becomes very clear, most hearable around 40-60% of speed, after that fans are become loud enough to mask it a little bit.
Below two recordings, unfortunately my crap phone didnt have loud dictaphone so you need to turn your volume up as much as possible:
1.
http://picosong.com/8xJS/ I start messing with it around 10 seconds or so, its most audible when I raise fans speed around 35 sec
2.
http://picosong.com/8xJK/ taken from a little bigger distance, around 45 seconds most audible after around 1 min 15 sec I was doing more faster switching between fan at very low speeds and above 40%.
I dont want to mess with the card too much it sits very firmly in my motherboard(Asus H170 Plus) and is secured to case with two screws, I dont see any cables touching the fans inside the card and cables around card arent either in much of a contact(still removing them didnt change anything). What can I do apart from possible RMA ?
I would really apriciate your help again
