Astral 5090 Low Power target and 3dmark scores
kampers
Hello i have buy Astra 5090 OC run in my setup and i think it's bitt slow, another user has mor fps and scores. I have reinstall windows with all new drivers. Don'ts different 😞 Look the pictures.
14900ks
Apex encore
48GB G skill 8200
Corsair HX1500i ATX 3.0 Tested with Asus adapter and Corsiar premium H+
Any tips ?
1 ACCEPTED SOLUTION
Accepted Solutions
kampers
Now will work better 🙂
I have clean my Windows 11 and try oc better 🙂
I replaced my PSU and i use new cable from corsair H++ work very nice >)
10 REPLIES 10
kampers
kampers
kampers
https://www.3dmark.com/3dm/128479467?
Windows 11 Home Latest update
I use Kolink PCI-E Gen 5.0 Riser Cable 90 Degrees - 300mm betwenn
Here it's min scores with 4090 Strix. Time spy Demo
https://www.3dmark.com/spy/48087218
Here it's scores for 5090 time spy demo
https://www.3dmark.com/spy/5411120920250314_210521.jpg
Hi @kampers
Those scores do seem low, you're right to question them. I know you're probably going to sigh at this question - but have you tried removing the riser and connecting directly?
Now, I do use a UPLINK GEN 5.0 riser and I don't have issues, however, I would certainly try to rule this out.
Also inspect GPU-Z and check the GPU has it's full ROP count.
HellRaiserChery
I have the same issue on my 5090 astral but not as bad as yours. I saw benchamrks on youtube of certain games and almost every game i have aroud 10-20 fps lower, even though i got an astral thats clocked way higher than in the benchmarks. So removed my 5090 and installed it on my old system with a i7-13700 and i got 10-20 fps higher and it varies with certain games but most of the games just had higher fps than my brand new 9800x3d system. Also i have an issue where if i dont use on every single game "perfer maximum performance" option on nvidia control panel, my gpu would just randomly keep downclocking from 2895mhz to around 1100mhz which causes a nasty stutter, When i turned off g sync the stutters were gone so its probably a gsync problem still not sure yet. Also putting my ram speed from 6000mhz to 6200mhz gave me a couple of fps. though but maximum performance is my fix for it. Here are my specs.
CPU: AMD Ryzen 7 9800X3D
GPU: ASUS ROG Astral GeForce RTX 5090 OC Edition 32 GB
MOBO: GIGABYTE X870E AORUS PRO ICE
SSD: Crucial T705 2TB PCIe Gen5 NVMe M.2 SSD
RAM: CORSAIR DOMINATOR TITANIUM RGB DDR5 RAM 64GB (2x32GB) DDR5 6000MHz CL30
COOLER: Lian Li Galahad II Trinity SL-INF 360 All In one CPU Cooler
PSU: LIAN LI EDGE 1300W Fully Modular ATX 3.1 & PCIe 5.1 80-PLUS Platinum
There's definetly wrong with my system but idk what is. maybe a bios setting or what not
This is my score for steel nomad with manual OC, and stock the result was the average around 14700
kampers
That GPU make me crazy ....
Driver Version: 572.83
Now in Assassin's Creed Mirage and Assassin's Creed Valhalla in benchmark i get 60fps and GPU Clock / 750 MHz.
Sometime in 3d mark i get on 15,700k https://www.3dmark.com/sn/4758818
Day after same profil i run 13k....
Never haven't problem with GPU like now
Silent_Scone
Super Moderator
Have you tried without the riser yet?
kampers
Hello
No, because i don't have a space in case 😞
