680 Sli problem In need of help
Fantasticcg
Hey
Recently rebuilt my computer reinstalled everything correctly.
Having issues.
In windows the Nvidia control panel does not recognise or give me the option to enable SLI.
Both cards are shown in the bios.
When in device manager a yellow ! sign on one of the cards appeared
There is one over the high definition audio as well, but from pass experience this has never caused an issue with
my GPU's.
Things I've tried is reinstalling Nvidia drivers
Uninstalling the cards from device manager
Installing missing USB3 drivers
Did wondered if a complete reinstall will be needed?
abvolt
Level 11
And you do have the sli bridge installed on the cards ?
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Arne_Saknussemm
Level 40
Best bet would be reinstall OS if you have moved OS over from another mother board or something like that. Though you could reinstall chipset drivers first.
Also I would not connect SLI bridge have the cards separate and reinstall Nvidia driver after starting up in safe mode and removing all things Nvidia with something like DriverFusion. Then when second card is recognised and set as PhysX card. Turn off attach bridge (maybe try another bridge?) and then set up SLUI....
