2080ti strix wrong led color?
Teletha
Hi I'm wondering if the led that shows that the pcie power is connected should be white? Cause the outer one is white while the inner one has a pink/purple tint to it. Should i RMA?
AMD Ryzen 7950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX TUF 4090 OC@3GHz [EKWB Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | 980+950 Pro 1TB M.2 | x6 850 PRO 512GB | NAS 4x 18TB Seagate Exo Raid 10+Backblaze | Lian-Li o11D XL | Main Screen: Samsung NEO G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | Copyright©1996-2023 Teletha™ All rights reserved. ® -"Lightning. It flashes bright, then fades away. It can't protect. It only destroys."
0 REPLIES 0
