hello,
i just received my asus strix 1080 ti and it seems to work perfectly
i wanted to test it in a game but as soon as the fans are activated, they are running at 100 % speed all the time .
even with corsair link, gpu tweak or afterburner, it says that my fans are at 0 %
it's possible to control them only if i restart my comp
i can aslo unplug the white cable at the end of the graphic card but if i put it back, it's the same issue
all drivers are up to date
i made a DDU uninstallation
i tried to install back my 980 but the same problem is happening
http://tinypic.com/player.php?v=iw3k1u%3E&s=9#.WQRVntqLQuXi hope you can see the video
i can't say if it hardware or software
should i send it back to reseller or contact asus ?
thank in advance
