TRANSCENDENCE EVOLVED
The ROG Azoth Extreme is a customizable 75% gaming keyboard with a premium aluminum-alloy chassis and metal frame. It features an 8000 Hz report rate with the ROG Polling Rate Booster and over 1600 hours of battery life in ROG SpeedNova 2.4 GHz wireless mode. The upgraded OLED touchscreen and three-way knob enable system monitoring and quick adjustments. The carbon-fiber positioning plate ensures a crisp typing sound, while three dampening layers absorb vibrations. An adjustable gasket mount with a paddle switch offers two typing preferences.
Superior build quality
The eye-catching ROG Azoth Extreme gaming keyboard boasts a premium aluminum-alloy chassis with a metal frame that undergoes an intricate 12-step manufacturing process that includes sandblasting, anodizing, CNC machining, and more. Additionally, the Azoth Extreme achieves an impressive 8000 Hz polling rate when used with the ROG Polling Rate Booster, while offering up to 1600 hours of battery life.
Crisp typing and sublime acoustics
The ROG Azoth Extreme uses a carbon-fiber positioning plate instead of FR4, steel, PC, POM, or brass, which are commonly found in other gaming keyboards. Carbon fiber offers metal-like rigidity for crisp typing sensations; and its elasticity provides excellent shock absorption to effectively minimize vibrations while typing.
The Azoth Extreme utilizes three dampening layers, with two PORON® layers and a silicone pad to absorb vibrations and minimize switch pinging and echoes to offer sublime acoustics.
Adjustable gasket mount
An innovative gasket-mount design allows users to adjust the typing feel via a quick-flip switch found on the bottom of the keyboard. In Hard typing mode, the Azoth Extreme delivers firm keystrokes with quick rebound that’s ideal for gaming. Alternately, Soft mode offers a more cushioned and bouncy feel to ensure comfort during extended typing stints.
Full-color OLED touchscreen
The 1.47-inch full-color OLED display on the upper right of the Azoth Extreme can show various types of information including keyboard connection status, Caps Lock, and PC/Mac mode indicators. Tapping and swiping on the high-resolution OLED screen allows users to view other various functions such as hardware info and the KPS feature that displays the user’s keystrokes per second.
Hot-Swappable ROG NX Switches
The ROG Azoth Extreme has pre-lubed ROG NX mechanical switches that provide smoother keystrokes with better acoustics.
Extendable Silicone Wrist Rest
Ensures comfortable typing experience and retains firmness over time.
