where can i purchase rog nomad backpack?
murjjin
rog nomad backpack....wher is it?
58 REPLIES 58
Phantzm
Excalibur and AMAZON are showing them as "In Stock" right now.
ASUS G750JM+
32GB RAM / SAMSUNG EVO 1TB SSD / 1TB HDD / BD-RW
ESO / RIFT / NeverWinter / GuildWars 2 / Thief / NWN & NWN2 /
TITANFALL / BF 2-4 / UT2004 / Q4 / Crysis 1~3 / Dead Space 1~3
BMWodarski
My order from excaliber pc just shipped out. woo!!!
AWESOME !! Let me know how you like it. I ordered mine from xoticpc.com, and they are expecting their shipment in today so hopefully they will send mine out by tomorrow. \m/
ASUS G750JM+
lonelycube
I ordered mine from excaliberpc and got it this morning.
I love the backpack. It perfectly fits my G750JZ and backpack is not as big as I thought.
Greate backpack.
Phantzm
I should have mine on the 12th. \m/
ASUS G750JM+
BMWodarski
Got mine today. Totally love it.
Phantzm
So UPS delivered my new R.O.G. Nomad backpack last night. I must say , it is a beauty !! I will test fit all my gear today after work to see just how much it can really hold.
Upon opening up the box and shredding off the plastic bag I started looking for blemishes and any other workmanship issues that I have experienced with other backpacks in the past. I found almost nothing wrong with the workmanship except for one loose thread which I quickly burned and let it melt so that it did not try to work itself loose and cause the seams to begin pulling apart.
Zippers: They seemed to be pretty good quality. Not the best I have seen, but definitely not the worst.
Storage Compartments: Very nice pockets and sleeves for most anything you would want to pack for a LAN party or travel trip.
Exterior: The exterior of the bag is really nice to look at. I like the red trim and accents, and the fact that the bottom is not perforated and holds it's shape pretty well. It is not solid , but it is rigid enough to keep anything from chewing it's way through it from normal wear and tear I would think.
Interior: The inside of the backpack is well padded and soft. I have no worries of my gear becoming scratched or gouged if it is placed properly within the pockets as designed. The laptop area is well padded as well. I could not tell just how thick the foam inside the liners is , but it seems to be more than adequate to keep things protected. I may look into an additional padded sleeve though just to make sure.
All in all I an really pleased with this purchase. If you can find it somewhere I do recommend that you get one. You already paid a pretty penny for your laptop, why not spend a little more to make sure that it is protected when you decide to take it out to play elsewhere.
I would post photo's, but I think all the images on ASUS' website have it more than covered.
\m/
ASUS G750JM+
Phantzm
OK, I've had the bag for a little bit now and I have noted one bad thing about it. Neither one of my keyboards will fit in it. I have the OLD SCHOOL Logitech G15 with the fold down LCD screen and a Razer Anansi. They are both too long. Oh well, not a major deal as everything else fits.
1- G750JM w/ PSU
2- MadCatz R.A.T. 7 MMO
3- Razer Naga Epic
4- 2GB USB HDD
5- iPod Classic 80Gb
6- iPad w/ Retina
7- Wacom Intous 4
8- 2x Glasses w/ case
9- Notepad & Pens
10- Kindle (Keyboard)
11- Misc. cables & connectors
So I am going to find a keyboard that will fit and will have everything I need to travel and play and still have room for other odds & ends. I am really glad I decided to purchase this backpack, even if it was a bit on the expensive side. \m/
ASUS G750JM+
heiligenschein
got to get one of this bags badly needed for my laptop
Let the future tell the truth, and evaluate each one according to his work and accomplishments.
The present is theirs; the future, for which I have really worked, is mine. - Nikola Tesla
