Solving a Marvell Hardware Conflict, how?
Durahl
Greetings!
I'm currently troubled by a hardware conflict issue I'd like to solve.
Problem description:
My current Motherboard ( EVGA X79 Dark ) appears to have it's USB 3.0 functions tied to the onboard Marvell SATA Controller.
Disabling the SATA Controller will also disable all my USB 3.0 Ports ( who ever did that should get whipped ).
Loosing the SATA Ports is something I don't mind as I'm not using them anyway but I'd like to make use of the USB 3.0 Ports which I'm running kind of short by now - But like I mentioned, one does not work without the other so I'd have to keep the Marvell SATA Controller enabled.
Problem is the RAIDR Express also being a Marvell based Controlled and those two don't seem to be on good terms with each other - With the RAIDR Express installed and the onboard Marvell SATA Controller enabled I can kiss a successful boot goodbye.
Question:
Is there something that I could do to make both controllers work along each other?
If so, how?
Thanks in Advance 🙂
0 REPLIES 0
