rog front base grrrrrrrr!!!!!!!
darren_midgley
anybody else got a frontbase????? :mad:
after a week of just trying to get all the functions to work i finally got it going. (nightmare!!!) am using a ranger board with a 4770k having a nightmare with the OC function the level up function is putting though way more voltage than it needs. where is it pulling these values from ??????? level 1 4.2g, level 2 4.4g, at level 2 it using 1.35v and even worse than that when i level back down to 3.9g it still putting 1.35v through!!!! i have configured OC profiles above 4.4g in my bios i can use but would like to use the front base. anybody front base experts here???? from what i can see the only good point is i dont have to go back to my desktop or look at my wrist to check the time grrr
please??? anyone????
many tnx
darren
HiVizMan
Level 40
The profiles have to take into account the vast difference between individual CPUs. I have a 4770K that requires 1.280 for 5GHz stable, and another that needs 1.440 just to clock to 4.3GHz. So it is very difficult to have a preset that is going to reflect the optimal voltages for your CPU.
As you have worked out BIOS overclocking is the best way.
The rest I can not really comment on sorry.
