ROG FRONT BASE - Equalizer is not working
ROGKANG
There is no EQ red bar and equalizer mode icon.
It's not just Invisible. I can't select EQ mode icon like It's not exist.
Escape Mode button is not working.
Overclock button is working LV1 only. There is no LV2.
and can't control PC sound volume.
I update all new BIOS, firmware and driver.
My OS is Windows 10. and MB is Maximus VII Ranger.
Please Help Me.
4 REPLIES 4
KMandalore
I'm also having this prob it was fine yesterday until I did a complete re-install of windows 10
KMandalore
Ok my dude, I may have just solved this.
So What I did was a Complete Unistall of the Drivers.... Then I went here to the Asus support page for the Hard ware.
http://www.asus.com/Motherboard-Accessories/ROG_Front_Base/HelpDesk_Download/
I downloaded the Utilities for window 10, and then I downloaded everything Else From Windows 7 OS mode.
Now It's working fine all my functions are back.
What did you install exactly?
Audio(Realtek Audio V6.0.1.7255) and Firmware(V47)? from Win7 64bit?
Gushy
Does not work on my Asus Rampage VI Extreme.
I did what you say, but does not work 😞
Everything else work just not that Quick EQ (equalizer) mode switch.
Anyone help ?
