RAIDR Express on P8z77-Vpro
jchambers2586
I have this board with GTX 570 SLI and a ASUS PCE-AC68 on the top blue slot.
will the SSD work on my board with the current configuration.
http://www.asus.com/Motherboards/P8Z77V_PRO/
This is my 1st Intel build.
jchambers2586
anyone?
DragonClaVV
I would say no.
The only possible Slot where you could put the raidr in is the last PCIe Slot. (The black one) Your manual says about the slot "at x4 mode, compatible with x1 or x4". The raidr is a x2 card.
3 possible things can happen:
-Raidr doesnt get recognized
-Raidr just runs at x1 what would kill her speed about 50%.
-Raidr works normally
to make that clear i would call asus directly.
The other way: sell your gtx 570s and buy one stronger card like the gtx 770. Then you could use the raidr in the second pcie slot.
Nodens
Level 16
It will work but at x1 speed. So it will be slow.
RAMPAGE Windows 8/7 UEFI Installation Guide - Patched OROM for TRIM in RAID - Patched UEFI GOP Updater Tool - ASUS OEM License Restorer
There are 10 types of people in the world. Those who understand binary and those who don't!
RealBench Developer.
