Missing Quick EQ after FW upgrade to v47
Joe1_vm
Dear all,
is anybody faced with missng Quick EQ options after firmware upgrade to v47? In fact red line on the bottom part of the dashboard disapeared and there is no possibility to select any EQ options in EDIT mode.
Also OC button requires immediate restart and drives Overclocking in BIOS "only" - not on-line under Windows. My MB is Asus Z170 PRO GAMING with latest firmware and OS is Windows 10.
Thanks for any experience sharing.
ROGKANG
It looks like my issue (https://rog.asus.com/forum/showthread.php?77594-ROG-FRONT-BASE-Equalizer-is-not-working)
but little different.
My OC button is working only LV1.(I can't select LV2) and Escape Mode is not working.
How about sound volume control? it's not working.
It looks really similar.
The volume control is working properly for me.
I asked Asus for explanation and they responded that the OC behavior can vary by MB type. Regarding Quick EQ they offered me some diagnostic. So I am going to return the panel next week to the vendor. Let's see....
