02-28-2015 06:43 AM - last edited on 03-06-2024 08:20 PM by ROGBot
08-31-2015 03:21 AM
Ruok2bu wrote:
I figured it out!
Here's exactly what i did:
- Unplugged all the ROG Front Base wires from the Unit itself and the motherboard.
- Plugged them back in and checked (with flashlight) they were securely plugged in.
- Installed the oldest version of the software (Version 1.01.06) but instead of using the AsusSetup.exe in the main directory, i first installed "ROGConnectPlus", restarted and then installed "FrontBase" and restarted again.
P.S. My version has a v44 sticker, so instead of doing the USB connection like others have pointed out on this forum, i simply connected the AAFP and ROG plugs into the motherboard.
08-11-2015 03:28 AM
Please test the Front Base on a fresh Windows 8.1 with the drivers that are available on the Official ASUS support page.
Even if the device worked previously on a Windows 10 we cannot recommend it as this product is not recognized officially at this point in time as being compatible with Windows 10.
If you feel the Front Base is not working within the official specifications on the official ASUS website I would recommend returning it to your retailer for a refund or replacement within warranty.
Best Regards,
ASUS Technical Support
08-12-2015 05:20 AM
Unfortunately these are the limitations for the ROG Front Base at the present time.
I'm glad to hear the Front Base worked on Windows 10 with BIOS version 2601 however it was never designed to in the first place.
As soon as new drivers, firmware, software or BIOS will be developed to grant full compatibility with the new Windows 10 OS they will be posted on the Official Support Page of the ROG Front Base.
Unfortunately at this time we do not have a time-frame on when that will be.
Best Regards,
09-15-2016 04:45 PM
03-20-2017 01:46 PM
04-21-2017 08:46 AM
05-19-2017 11:06 AM
05-24-2017 07:26 PM
08-14-2017 01:34 AM
