02-28-2015 06:43 AM - last edited on 03-06-2024 08:20 PM by ROGBot
05-28-2015 02:14 PM
05-29-2015 12:13 AM
stricken404 wrote:
Nope. Neither of them work. Both of them open an installshield wizard tab in the task bar that does nothing. My motherboard is at the second latest drivers (since the latest ones came out like 3 days ago). When I go to kill the InstallShield Wizard using Task Manager I get a pop up message after it kills it that's titled "Wonder Box Driver" "An error occurred while launching the setup" "The remote procedure call failed"
06-07-2015 12:51 AM
07-14-2015 07:21 AM
08-03-2015 11:03 AM
08-05-2015 01:23 PM
08-06-2015 11:19 AM
08-07-2015 09:05 PM
08-08-2015 01:59 PM
08-08-2015 04:02 PM
Ruok2bu wrote:
I figured it out!
Here's exactly what i did:
- Unplugged all the ROG Front Base wires from the Unit itself and the motherboard.
- Plugged them back in and checked (with flashlight) they were securely plugged in.
- Installed the oldest version of the software (Version 1.01.06) but instead of using the AsusSetup.exe in the main directory, i first installed "ROGConnectPlus", restarted and then installed "FrontBase" and restarted again.
P.S. My version has a v44 sticker, so instead of doing the USB connection like others have pointed out on this forum, i simply connected the AAFP and ROG plugs into the motherboard.
Did this work for you? +Rep me.
