on
06-25-2024
09:55 PM
- edited on
06-25-2024
11:20 PM
by
MasterC
Power Detector+ feature helps you monitor and identify power issues with your GPU.
With the advanced Power Detector+ LED and features in ASUS GPU Tweak III, the ROG Matrix GeForce RTX 4090 Platinum can detect various anomalies across the six individual pins in the 12VHPWR cable. By immediately warning the user of these detected anomalies, this detection system helps maintain optimal performance and prevent potential hardware failures.
If LED flashes this could indicate:
Links:
ROG Matrix GeForce RTX 4090 Platinum 24GB GDDR6X
