02-06-2024 03:00 PM
So i showing multiple power connectors one is ATX Looks like 24 pins and 2 8 pins do I connect them all or just the 24 pin
Solved! Go to Solution.
02-07-2024 03:53 AM
thanks, you wish they show or say better in their book found out since.
The 24 Pin powers the MB and
two 8 Pin powers the CPU
these newer mb have lots of connections compared to 14 years ago when i build my last one thank you in your reply.
02-06-2024 04:22 PM
Hello jkamer
The 24-pin main power cable is mandatory.
One 8-pin cpu power cable is mandatory.
If your psu has two 8-pin cpu power cables, connect both to ensure stability, especially if you're overclocking.
I personally connect both 8-pin cpu power cables to my ROG Strix Z690-F Gaming Wifi.
02-07-2024 03:53 AM
