z790 hero ethernet problems
GuzMonster
When gaming the ethernet adapter freezes for a couple of seconds making the experience unplayable. If I use wifi this does not happen. I've tried both I226 ethernet drivers versions 1.1.3.28 and 2.1.1.14 with no success. Is the adapter that comes with the board broken? Any one else with the same symptoms?
z790 maximus hero
13900k intel
4090 geforce
tforce 7200 ddr5
12 REPLIES 12
GuzMonster
Did a network reset in windows which changed the driver; now it seems to be working fine; fingers crossed.
z790 maximus hero
13900k intel
4090 geforce
tforce 7200 ddr5
tried same and no luck
eLem3ntx
Having the same issues - even my 10GB NIC card inserted stops for several seconds not only the internal RJ45 on the board itself.
Also Inernet/Ethernet is stopping for around 30s if I connect to a VoIP liek discord or teamspeak.
1GB full duplex didn't change anything 😞
