11-09-2022 03:42 PM
11-15-2022 03:22 PM
GuzMonster wrote:
Also happens while gaming is it normal?*
11-15-2022 04:31 PM
11-15-2022 04:43 PM
11-15-2022 05:06 PM
11-15-2022 11:06 PM
GTGhigo wrote:
try remount the aio cpu block, possible it got bad contact and while at it get this first https://a.co/d/1jw89tV will gain usually 2-5 degrees as stock retainer like bend a bit cpu ihs
11-16-2022 10:32 AM
11-16-2022 06:27 PM
11-16-2022 08:26 PM
GTGhigo wrote:Â*
Then look this guide https://www.overclock.net/threads/asus-maximus-z790-extreme-and-intel-i9-13900k-a-tuning-guide-for-b... first part is jsut notions but you want do the part where let you reduce a lot vcore voltage under load , i am now runing 1.21 without any problem in cinebench and temps at 70, 40k+ score, search in the thread "But we want to UNDERVOLT the CPU, right?" that the part you want
11-17-2022 02:29 AM
GuzMonster wrote:
Â*
i did undervolt following what is said on that thread but my cpu is not that good; I only had a moderate improvement. BTW which cooler are you using?
Noticed the red light is gone when going from bios 0088 to 0703; but the throttling problem is not solved. *
11-17-2022 12:07 PM
GuzMonster wrote:
Yes It was a bad mount. But I still get core thermal throttling using cinebench at stock settings. I’m getting the frame anti bending and see if it helps.*
