Z790-e wifi 6e (40MB/s) slower than wifi 5hz(58MB/s) on mine rapture ax11000 pro!?????
AlexPaska
Ethernet max is 650 MB/s
I turn on my mobile spot in win 11, have latest driver for wifi 6e 160hz, but speed is lower then on 5hz on mine router(rapture ax11000 pro). Speed also is not stable from 27 - 40 MB/s, nothing downloading in that moment....
Can u help??? Why motherboard wifi 6e is soo slow....
JohnAb
Level 17
Your issue might be to do with range, the 6E signal drops off a lot faster than the 5G band. Try moving your PC closer to your router as an experiment and see if that helps. If the problem is just as simple as range, then you might just get better speeds from the 5G band. I've been lucky with 6E and I do get better speeds, even through two walls and being 10-15m away from the router, but it can depend on the location of your equipment and the transmission power of your router.
Z690 Hero, 12900K, BIOS 3701, MEI 2407.6.1.0, ME Firmware 16.1.32.2473, 7000X Case, RM1000x PSU, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 23H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
Sorry, i missed! From router ethernet come to PC, and i tested, when i am from 10 cm antenna motherboard wi-fi (the motherboard wi-fi!! not connected to router!!) , speed is to slow against router 5hz????
