01-23-2022 11:18 PM
01-25-2022 11:44 PM
01-26-2022 12:04 AM
01-26-2022 12:12 AM
awesome14 wrote:
The USB 2.0 spec is 5V 500mA (0.5A) per port. The USB 3 spec is 5V 900mA (0.9A) You need to find out the total deliverable power to all the ports. The port will only deliver what the device asks for, sometimes even less on lappys. Are you using a hub?
02-06-2022 09:29 AM
junkyard2902 wrote:
Before I was using the headset on USB 2.0/3.0 ports and it functioned without any issues at all. I have currently connected the Mouse and Keyboard to USB 3.2 Gen 2 ports for them to work without any issues. It is only the 3.2 Gen 1 and USB 2.0 ports on this motherboard causing this issue.
I am not using a hub. But how do I find out the total deliverable power to the ports? I also don't think the HyperX Cloud II is requiring that much power.
02-06-2022 11:48 AM
Jimbo93 wrote:
I would try to eliminate the possibility of a software conflict by disabling optional startups per standard troubleshooting. Also just on the off chance something is screwy with power settings in windows, run the power troubleshooter in control panel troubleshooting. But if this does not help then I would look to using latest drivers and bios. Have you tried MoKiChU driver packages? The best. You might need to post the question which drivers for your board unless it was previously answered by MoKiChU in the subthreads. https://rog.asus.com/forum/showthread.php?119120-INDEX-All-My-Firmware-Drivers-Software-Threads
Also check out his tool Driver Store Explorer for cleaning up old drivers. Awesome tool.
03-12-2022 06:56 PM
04-08-2022 01:12 AM
04-08-2022 01:58 AM
Jonald wrote:
I'm having the same issue as well - seems like power to the USB ports (Front and back) seems to momentarily drop which is causing all the issues.
I've done pretty much everything that is possible as well, agree that these issues only occur under medium -heavy load.
Thought it could be a PSU issue so bought a new 1000W Asus PSU and still the issues persist.
Only difference is I'm on Z690-Maximus Hero.
Hoping someone is able to help
04-08-2022 07:37 AM
