I'm not sure about what BIOS settings might work best, but I use a separate device for charging all sorts of extras via USB- very useful. I wouldn't be without mine now. I attach a picture just as an example, but lots are available up to 100W output for charging laptops, phones - you name it. Worth taking a look... I usually have at least 3 devices plugged into mine and I never need to worry about the power needed. So convenient. You also get the benefit of full fast-charge support depending on what you choose.
Z690 Hero, BIOS 2305, ME Firmware 16.1.27.2176, 7000X Case, RM1000x PSU, i9 12900K, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 22H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
