XMP problem with Z790-H
Clansman79
Hello, it's a bit difficult to explain myself in English, I hope you will understand.
I set up my new PC with this configuration :
Strix Z790-H
Intel I5-13600KF
Corsair Dominator Platinium 2x16 6400 ( A2/B2 )
(CMT32GX5M2B6400C32)
Everything works, installing Windows 11, updating the bios, and using overcloking AI.
Wishing to take advantage of the speed of my RAM I enabled XMP by default. Black screen and no boot.
I've been trying to find information online, the problem seems to be frequent and requires adjustments.
I keep XMP on, and I change 6400 -> 6000 same problem.
6400 -> 5600… same problem…
6400 ->5000 ok… Windows starts.
( but I haven't done a stability test)
I don't know enough about overclocking, I just want to take advantage of my Corsair 6400 kit.
Thanks a lot
1 ACCEPTED SOLUTION
Accepted Solutions
Clansman79
Hi, I had to change my motherboard, no more problems... it takes the XMP1.
Thanks
Silent_Scone
Super Moderator
Hi @Clansman79
Set XMP II, if issues persist - tune the following rails.
Inspect auto values and tune incrementally.
Extreme Tweaker > CPU System Agent
Extreme Tweaker > Advanced Memory Voltages > Memory Controller Voltage
Extreme Tweaker > Advanced Memory Voltages > IVR Transmitter VDDQ
Thanks, my Corsair AIO is defective and I still haven't been able to test.
I hope I can do it on Wednesday
Clansman79
Thanks
