Whea error when PCIe power management control is enabled
emred
When will this problem be solved? I have latest SSD 990 Pro firmware and latest bios asus z790-f gaming wifi. Issue is still persist.
13 REPLIES 13
jackenpacken
Disable ASM1061 on BIOS onboard devices.
Does i don't need this ASM1061 sowhere in my windows?
i9 14900KF (DD) P:5.9/6.1(+2 Boost allcore)E:4.7/C:5.0 @LLC5 1.295v; Z690 Formula; 2x16GB 6800MHZ CL32; TUF RTX 4080 O16G; 2x 32" LG 4K @60Hz all watercooled with Mora 3 and 3x360mm intake, all in Lian Li O11D EVO XL
The-Pack
Both doesn't help by me...
emred
Well I'm pretty sure this not affect everyone cause not everyone has 980Pro-990Pro ssd. Also not everyone using Balanced Power Plan on windows(High performance plan is disabling power saving feature for pci express and it's also can help for ignore whea errors.)
