USB 3.2 Speed Issue on z790-E
jcbell3
I have a Z790-E which has a usb 3.2 Gen 2 type-c port on the back. it is supposed
to be very fast. i have tested it and it has speed right in line with a usb2 port. the
front panel usb3 connectors are 10 time faster. i have the latest bios and all the
latest drivers. is this a hardware problem which needs an RMA or a driver issue?
Thanks.
fwiw
Product Model & S/N:
ROG Strix z790-E Gaming WiFi
BIOS/FW Version 0816
CPU: 13th Gen Intel Core i9-13900K
Memory: 64GB
HDD: Samsung SSD 990 Pro 1TB / Samsung SSD 990 Pro 2TB / Seagate ST8000VN004-2M2101 - 8TB
VGA: AMD Radeon RX 6750 XT
4 REPLIES 4
JohnAb
Level 16
Can you see UCMCLIENT listed in Device Manager?
If not, see this thread: https://rog.asus.com/forum/showthread.php?131960-Help-with-Device-Driver-missing-Occur-after-Z790-08...
Z690 Hero, BIOS 2703, MEI 2316.5.0.0, ME Firmware 16.1.30.2264, 7000X Case, RM1000x PSU, i9 12900K, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 22H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
Never mind. I had a bad cable. bought another one and all is good. Also,
why isn't the text showing when i (try to) look at a post. Can see it if i
view source. using Edge. thanks. Also, i am not seeing UCMClient in
Device Manager. where is it located? i Asussetup in the ucm folder.
JohnAb
Level 16
Go to MoKiChu's drivers threads and grab the latest Thunderbolt drivers. They contain the UCM drivers, Asus drivers do not. It's explained in the thread link I suggested above...
ahfoo
Thanks.
fwiw
Memory: 64GB
Just update all relevant driver provided by MoKiChu. Also USB data transmissions also required receiving end hardware capable. Some controller on the receiving end may also cause the issue too.
