06-15-2023 07:08 PM
Hello there! This is my first post here, but here it goes: I'm building my first PC and when booting for the first time, I updated the BIOS to the latest version, but every time I power up the PC the red Q-LED (CPU) stays on, but the weird part is that there's sometimes I can use Windows without issues. I checked the CPU, reseated, broken pins, everything, but nothing, again, I can use Windows and even check the CPU's info.
Fans and AIO are working just fine, memory is working fine too, also checked the PSU, but nothing.
Maybe I need to apply warranty and change my mobo??
What else can I do?
Thanks in advance for the help
06-15-2023 10:19 PM
Welcome 🙂
1) Can you confirm if the behaviour occurs at complete defaults?
2) Try also reseating the DRAM
3) Try clearing the CMOS by using the Clear CMOS header (#13)
06-16-2023 10:23 AM - edited 06-16-2023 10:26 AM
1) I can confirm it even happens with defaults.
2) Already tried, same result.
3) It only boots directly into the BIOS.
I'm adding extra info:
CPU: Intel Core i7-13700K
32 GB RAM DDR4
MSI-AIO
1 TB NVMe
I can see all the system's info in BIOS (specifications, temps, voltages), I don't know at this point if the CPU could be causing issues, I don't have another PC to test the processor and the rest of components.
I'll attach an image with the screen I get every time I boot. (BIOS version 1002)
06-16-2023 10:05 PM
Hello,
So resetting the CMOS allows you to boot into the BIOS - what behaviour is exhibited when you attempt to boot into the OS?
06-16-2023 11:06 PM
It just shuts down, then powers up, but the Q-LED (CPU) remains on, sometimes I can get into the BIOS, sometimes not.
I can't boot Windows now, it seems that not restarting has causes the OS to not boot (a blue screen appears).
I reseated the CPU again, and after powering up, I got a message telling me that the mobo detected a new CPU, so that can discard the CPU as the root cause.
At this point, I've tried almost everything, I could try with another CPU, but I don't have friends with compatible CPUs.
06-16-2023 11:09 PM - edited 06-16-2023 11:16 PM
It depends what’s causing the stop code. Are you able to capture what it is or enter boot recovery mode? Windows should enter this automatically after a few attempts.
Can you confirm you are not enabling XMP profiles, also.
06-17-2023 06:00 PM - edited 06-17-2023 06:07 PM
Yep, no XMP profiles active.
On Windows I get the invalid boot device message, but that's because I still have issues figuring out why it can't boot normally.
06-18-2023 07:46 PM
Quick update: I'm able to enter Windows 11 at times, it's just the randomness of being able to boot to Windows that still is making me wonder what's going on.
06-18-2023 09:34 PM
Hello,
This was an issue with a particular version of Intel’s chipset driver (v10.1.19222.8341) when paired with 13th gen CPUs where after a subsistent reboot the system would halt on that stop code. Perhaps make sure you’re not using that version and attempt to rollback/reinstall.
06-19-2023 05:54 PM
I checked and I don't have that version of the controller, also, I still have the red Q-LED issue, is there any specific test I need to perform to finally solve this issue??
