Thunderbolt Downgrade NVM31 Solution for Thunderbolt 2 devices
psikofunkster
Hello,
Today i found this:
on my mobos bios and software section
https://rog.asus.com/motherboards/rog-maximus/rog-maximus-z790-hero-model/helpdesk_bios/
I'm used to update my hardware but what about this? this a downgrande, should i apply it or forget about it?  I read there is a risk involved so i guess the answer is no, but what was the problem on the first place? am i affected?
1 ACCEPTED SOLUTION
Accepted Solutions
JohnAb
Level 17
As far as I understand it, z690 motherboards (and maybe Z790 too) were supplied with Thunderbolt firmware v31.0. Bios 2204 (and above) upgraded this firmware to v36.0 which was buggy and disabled support for Thunderbolt 2 devices. So you are probably on v36.0 now like me. You can find out by installing the Thunderbolt Control Centre - I have it installed, but can't remember where I got it from. I think it was from the Microsoft Store, but I can't find it now.
Anyway, unless you are having issues, or don't even use Thunderbolt, then no need to do anything. It's just for those people having problems. On the other hand, I think that v31.0 might not properly support some Thunderbolt 4 devices, depending on what controller they use. This is just based on what I've read before, no personal experience.
Z690 Hero, 12900K, BIOS 4505, MEI 2546.8.9.0, ME Firmware 16.1.40.2765, 7000X Case, RM1000x PSU, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 25H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
8 REPLIES 8
JohnAb
Level 17
psikofunkster
Many thanks for replying JohnAb.
PerpetualCycle
This showed up for my Z790 Dark Hero. Currently I am on NVM version 42.3.  Not sure if this is relevant for me. Asus should provide more information instead of just shoving a firmware downgrade to us with no explanation whatever.
ROG Dark Hero Z790 | 13900KS @5.7 GHz | g.skill 2x48GB 6800 MT/s | ROG Strix 4070 Ti | EK Nucleus 360 Dark | 6TB SSD/nvme, 16TB external HDD | 2x 1440p | B&W 606 S3 speakers, RSL Sub, Audiolab 7000A amp| Fractal North XL case
PerpetualCycle
I was curious so I  downloaded the firmware downgrade zip from the Z790 Dark Hero support page and it did not even include a firmware to downgrade to! All it contained was a readme.txt and a shell.efi, no firmware file.
It says you need to launch 'shell.efi' from BIOS. But don't do it, not unless you have problems.
It also says to extract the firmware file and shell.efi and load it onto a USB stick.
I am not going to do it, but just pointing out you can't if you want to without the firmware file.
sdmf74
Level 11
Why Did Asus put the Thunderbolt NVM31 downgrade on the Maximus 13 Hero driver page?
I just checked in Thunderbolt Control Center and my most recent TB driver is NVM26. I dont think its supposed to be for Z590.
ASUS Maximus 13 Hero, Intel I9 11900k, EVGA GeForce RTX 3080 FTW3 ULTRA
NotAGamer_01
Wasn't the purpose of the downgrade to give back the ability to be backward compatible with TB2 devices?
Many users lost the ability to connect to their TB2 devices based on the changed that the newer BIOS version made and people were asking for the ability to downgrade back to the earlier aspect.
If you are someone who need this you clearly know because you have been asking for it for quite some time.
