Strange Aura issue with Z790-A and Strix 4090
pdixon0
Hey guys
I'm seeing strange behaviour with my Z790-A (D4) and my Strix 4090. I like my Aura colour scheme to be the rainbow purple / magenta fade and have it applied to my Z790-A, G.Skill Ram, ROG Scope RX keyboard, ROG Gladius III mouse and of course my ROG STRIX 4090.
When I start my PC, most of my RGB stuff does it's own thing (standard full colour rainbow) except the 4090 which remembers it's last setting. When I get into Windows and my other RGB stuff picks up the signal to set the correct colour settings the 4090 then goes back to the standard setting (which is called Cyberpunk) even though it is set to sync all devices in the Armoury Crate screen.
Opening Armoury Crate and unchecking and rechecking the 4090 gets it to the correct RGB setting which is great, but each time I reboot or start the PC from fresh I am presented with the same issue.
Other than trashing Armoury Crate does anyone have any ideas?
5 REPLIES 5
pdixon0
As an update, I have uninstalled (deleted all references to Armoury Crate etc) and reinstalled to no avail. Just seems weird.
Is there a set of logs for AC by any chance?
JohnAb
Level 17
I had very similar issues, with Aura lighting working inconsistently. Once I set a scenario profile which can be triggered by whatever programs you select, things are much more consistent and I don't even need to start Armoury Crate for that to work. Sounds like your lighting behaviour is quite normal to me, just try the Scenario profiles and see if you can fix it that way.  You will still get RGB lighting on defaults until the profile starts though. I set up a profile called Music which means that all 3 of my ARGB headers now create some nice effects when I'm using Music Bee to play music.
Create a new profile in the main screen (below) and then edit in the screen above
Z690 Hero, 12900K, BIOS 4505, MEI 2546.8.9.0, ME Firmware 16.1.40.2765, 7000X Case, RM1000x PSU, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 25H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
I actually have a profile set up for when I play MSFS - all of my RGB goes solid orange to match my Thrustmaster flight stick, this then returns to the purple / magenta fade when I come out of MSFS.
When the 4090 doesn't pick up the correct RGB, it also isn't triggered by the profile either - like it's not detected - yet it shows straight away in AC.
Odd. My 3090TI seems to do it's own thing sometimes as well. To be honest I'm not too bothered, as long as the lights cycle most of the time I'm happy. I also use iCue for my case fans and AIO fan RGB lighting. I have disabled the GPU lighting in iCue, but I guess there could be a conflict under some conditions.
pdixon0
Weird thing is, I've had this happen for a few months now - now I've asked about it on here I've just booted my PC and the 4090 RGB has worked as expected - figures!
