10-28-2025 10:27 AM
10-28-2025 02:35 PM
I was thinking that the flashback button could be stuck, but in that case I think it's likely that it wouldn't click. Perhaps the switch is broken internally, but I think that's not likely.
Could you try fiddling with the switch and seeing if you can get a boot without the flashing LED? If so, leave it since you won't need it, just use Flash Back 3 in the BIOS instead (or RMA the board if nothing helps).
I don't know what else to suggest.
10-28-2025 02:51 PM
Thanks for the reply. i tried fiddling with the flashback button/switch dnd it did not help either. always i need to use psu button and power button simultaneosuly to switch on. i have contacted asus support the pointe me to this link https://www.asus.com/support/faq/1042632/ in that link they did not mention anything about bios flashback led. i have contacted again with the details. let me see what they say.
10-29-2025 02:13 AM
No problem and good luck. Seems like an odd issue.
11-01-2025 10:26 PM
Asus asked me to RMA via reseller. I am sedning it for RMA. it may take a month to get a resolution for the RMA.
3 weeks ago
I have this same issue. Please let me know when they fix it and how it goes.
3 weeks ago
The retailer send it to asus and in end the they are refunding me. I upgraded to ProArt z890 and Core Ultra 9 285K.
