New pc build z790 f wifi ii no display and fans not spinning on ryujin 360
Kendawg69a
Have a new pc build I'm having trouble booting. everything has power except for fans on ryujin 360 iii. Was able to do bios update but can't seem to get a display to install windows. Is there a key I press to boot to bios? Will i need gpu hdmi to display bios or motherboard hdmi to get a display. New to aio pc builds any help appreciated!
Asus z790 f wifi ii
Core I9 14900k
Asus ryujin 360 iii
Nvidia 4060 ti
Corsair 6000mhz
Asus rog Thor 1600w psu
6 REPLIES 6
Vynra
are you 100% sure you plugged everything in correctly? all it takes is one missed connection or one loose connection not plugged in to make it not work
I haven't built a pc in 20 years but I'm just using aio fans which are not spinning without software setup. I remember my first pc build would not boot if I unplugged the rear fan which I don't have one installed. Aio is all plugged in. all of my mobo test lights are out it is fully built except for a rear fan which I haven't ordered yet
the ryoujin should still spin even without software. make sure it is plugged in correctly.
3 connections and usb 2.0? I cant figure out why everything has power except for fans. No controller came with setup it shows different aio installs online with a controller but this came with no controller
Kendawg69a
Need any other pics just ask
Does mobo need m.2 to boot or can I use 870 evo ssd
