01-06-2024 09:10 AM
I built a gaming computer 2021 and these are my specs,
Asus ROG Maximus Hero Z690
Intel 12900K
2x G.Skill DDR5 16G memory @ 6000MHz
3 x Samsung 980 Pro
Nvidia ROG 3080 ti
Since first day I have had this issue that if I unplug the power the computer cannot POST and gets stuck in q code 99. Usually clearing CMOS etc has done the job to boot it once and then after that it works flawlessly,
Two days I accidentally unplugged it and since then its been stuck in q code 99. tried everything from disconnecting components to bare bones and clearing CMOS, but nothing works. I read somewhere that flashing the MOBO to an earlier version might help and when i did the USB BIOS Flash it stopped showing anything on screen and now its just a black screen. This is really frustrating and love any help that you can provide.
01-07-2024 02:00 AM
Sorry to hear that. I can only suggest that you keep trying to flash the BIOS again, power off at the PSU, remove the battery, reset the BIOS again, etc. Hopefully something will work. It's lucky that you have the Flashback port.
This is a longshot, but have you tried another PSU and/or monitor? I'm just thinking that cutting the power could have damaged the PSU, although I think it's probably unlikely.
