11-04-2022 02:06 AM - last edited 3 weeks ago by ROGBot
11-15-2022 06:27 AM
moonshadow88 wrote:Which specific setting did you change in the asus bios?Â*
Well,
After spending all weekend beeing a plumber and adjusting BIOS config, It turned out that the problem was BIOS config.
Using this guide:
https://www.overclock.net/threads/asus-maximus-z790-extreme-and-intel-i9-13900k-a-tuning-guide-for-b...
I have tammed the beast.
Final result:
Â* Â*I tried the loop with one rad (360), serial and parallel. Finally I kept two rads and CPU and GPU blocks in parallel because the temps are almost the same (on serial config the temps are 2º lower but tubbing is a lot easier).
Final bios config:
- P-cores: 57x2/56x4/55x16
- E-cores= 46x2/45x4/44x16
- VCore: 1.19
- CPU wats: 240W
Full load temps:
- CPU: 83º
- GPU: 63º
Thank you @ll for your help and comments!
