Have anyone an USB problem after installed Intel Chipset Driver 10.1.20062.8627 via ASUS DriverHub?
quentin_sec
I have USB Problem after installed Intel Chipset Driver 10.1.20062.8627 via ASUS DriverHub. Because When I installed this driver and then logged into my Windows, all device that connected with USB to my PC not working. The LED status, RGB Light on those Device are turned off. Luckily, I have a restore point of Windows System Restore can help me. My Motherboard is PRIME Z690M-PLUS D4
JohnAb
Level 17
I'm on a later version (10.1.20266.8668) which you can get from here:
https://rog-forum.asus.com/t5/downloads-for-motherboards/drivers-intel-chipset-mei-vmd-serial-io-gna...
Not sure if your driver is causing the problems, the older version worked for me too, but the latest version might be worth a try.
Z690 Hero, 12900K, BIOS 4301, MEI 2517.8.1.0, ME Firmware 16.1.38.2676, 7000X Case, RM1000x PSU, ASUS TUF OC 3090TI, 2 x 16GB Corsair RAM @ 5200MHz, Windows 11 Pro 25H2, Corsair H150i Elite AIO, 4x Corsair RGB fans, 3x M.2 NVME drives, 2x SATA SSDs, 2x SATA HDs.
Wesley1
Level 12
The 10.1.20062.8627 package might be for z890 boards. It should work on older board too, but who knows.
Try offical one:
https://www.intel.com/content/www/us/en/download/19347/chipset-inf-utility.html
