GPU stuck in X8 no NVME drive, no PCIE devices plugged in
tonycstech
Z690 Maximus
i9 12900KS CPU
GPU stuck in X8 instead of X16. You can see it in the BIOS screen.
No NVME drivers.
No PCIE devices plugged in.
Used latest GPUZ to confirm the issue.
Tested PCIE lanes to the CPU with a tester, PASS
Tested GPU for PCIE lanes with a tester, PASS
Tried another GPU,  same result.
Update to latest firmware, same result.
Anymore ideas ?
Bios tweak maybe ?
44 REPLIES 44
FixItWorse
Man, I've been working a ton recently and didn't get a chance to really read over this until now.
So!
1. I do, if you're a serious builder, yes you do. I research my motherboard purchases exhaustively in every way I can before making the purchase, just by buying a pricey one, you're asking for trouble (I did that, ehem... Z690 Aorus Master that I evenutally broke some socket pins on while cleaning paste with a Q-tip, $500 mistake, learned the hard way).
2. Its a general public assumption that you can populate every slot and have top slot be X16 at all times unless there are some OBVIOUS limiting factors such as NVME drivers etc which is not the case here.
Well no, you're just plain wrong there. If the world of custom pc building were actually defined by the mob of "general public exception" on reddit, then independent repair shops would be rich, fixing people's self built machines who spent too much money because they thought that equaled better, I too fell victim to this, with higher costs, comes specialization, obscurity and products that don't conform to the norm. It's the same in virtually every industry.
Here's food for thought, when I would frequent reddit trying to help people, I kid you not, 85% of peoples' advice given was false a minimum, and would often make no difference and it some cases down right dangerous.
And by the way, your NVMEs slots and PCIE slots are basically the same thing.
GEN5 Intel ROG boards are designed for the eventual day of Gen5 GPU's and Gen5 HyperCards populated with 2 GEN5 Nvme drives. Then you will be saturated just like you want. So, rough estimate... Something like 3 grand just so you can have fully occupied lanes, but will they be saturated!!!? Nope. Everything will have loads of headroom and revisions a plenty for years to even approach it.
3. The fact that is problem should not exist is proven by endless posts of people trying to solve the  none existent problem "as asus would put it" allover the forums.
My man, you don't know what you don't know. If you really wish to be in the know, saddle up, go to Microsoft Learn and start researching things like OEM System Bring Up, WHK Tests, DISM and custom image prep testing and deployment. And the list goes on and on. Then do the same by reading the big 4, Intel documents, 2 for your Silicon, and 2 more for the Southbridge, Aka, PCH the collection previously known as the chipset. There's probably about 1200 pages or so there to keep you busy, and make sure to let them know what you would change there as well. I hear they really appreciate that.
I wanted to help you man, but if you're a person with reasonable financial resources, part with the things you have build wise now, and get a Falcon Northwest.
You will be happier, I promise.
As i read your screenshot of the manual, i cant even wrap my head around how to interpret that.
The word "supports" should be removed and replaced with "will limit" because otherwise it seems like it supports both X16 and X8 so yeah, i should be able to get Х16 in both slots or i can also have X8 in both slots. How ever i like to set it in the BIOS is what it will do.
Thats how i would interpret that.
Hisense U7G 55" 4K, HDR, 120hz w/FreeSync VRR Primary Display
Corsair 5000X Black iCue, ROG STRIX Z690-E GAMING WIFI w/ Intel 12700K, AIO Cooled by Corsair H150i Elite Capellix, Gigabyte Aorus Master RTX 3080 Ti, 64GB (4x16) Corsair Dominator Platinum @ XMP I, 4x 1TB WD850 Black NVMe, 2x on HyperCard in Raid 0, and 2x in M2.2 and M2.3 on Mobo.
SeaSonic TX1000W Platinum PSU, Corsair K70 RGB MK2 Wired Keyboard, Corsair M65 RGB Ultra Wired Mouse, Logitech Brio 4K w/Windows Hello Face. Windows 11 Home 23H2
tonycstech
My old Z170 Pro motherboard did not have this problem, why this new top of the line junk does ?
Also why while gaming sound turns into white very very loud noise ?
What in the world is wrong with this garbage ?
FixItWorse
You accuse others of not listening to you, and then when I give you a lot to chew on, you answer with truly ridiculous brief statements.
Simply put, you do not possess the true foundational skills to be building and maintaining your own PCs at least not PC's that meet your High bar of quality.
If you are not here with specific technical questions, and just to bash Asus, then I for one cast my vote to have the topic closed please.
tonycstech
Technical question:
Why old motherboards such as Z170-K does not have issues Z690 does to a point of an official recall ?
My guess its because quality control went diverse.
The Z170 flagship only had 8 physical lanes to the second 16th length slot (due to number of lanes available).
The first slot also shared bandwidth with the second full length slot, much like your current board. You seem to be reaching with this one and I'm not sure why, it's quite odd. Passive adapter or not, the slot is occupied. You could always try putting your finger in there and see if it detects that too (just kidding 😂)
