Desperate Cry for Help - 14900KS + Apex Encore + G.Skill 6800J3445G32GX2-TZ5RK
Mikep15665
Hello everyone,
So I bought the configuration specified above - Great 14900KS chip with high P and E scores, but with an MC score of 87.
SP score is 113.
I'm using the Liquid Freezer II 420 and made sure the contact frame is not too tight or too loose.
Issue: I'm trying to activate the XMP profile for the G.Skill 6800J3445G32GX2-TZ5RK, but the PC simply would not boot, and if it does, I immediately get a BSOD error. I tried running the XMPI and II even with slower DRAM Freq such as 6200mhz or even 6000mhz, but to no avail.
Even attempting to manually increase the following voltages didn't make a difference:
  • CPU System Agent Voltage to 1.2v
  • DRAM VDD & VDDQ to 1.45v
  • IVR Transmitter VDDQ and Memory Controller Voltages to 1.3v.
SVID behaviour is set to TRAINED, and anything other than the values I mentioned are set to AUTO.
Other than purchasing a different kit, I honestly do not know how to troubleshoot this any further, thus humbly asking for help.
Any suggestion, guidance will be highly appreciated.
Thanks in advance,
Mike
10 REPLIES 10
gur_helios
Try following steps. First of all, load the default settings by pressing F5. After that, choose the Intel Default Profile with XMP activated. Let the SVID behavior on AUTO (not TRAINED) and don't make any changes of the TVB settings (let them as they are after choosing the the Intel Default Profile. TVB should then be enabled by default).
Is the system starting up without errors or crashes?
LinkedIn:
https://ch.linkedin.com/in/uwe-ruch-2a82a08b/en
